Tutorial New AMD macOS CoreCount patch Information
sac23
Are any of u guys on beta 4 with no Bluetooth thanks in advance
Khogao
I am on B4 and BT is disabled. My spec: 1700x, MSI B350M, RX580, NVME Pm961, Wifi& BT: Bcrm94352z.
khalifa
Hi and thanks in advance.
I'm having some trouble, sorry if this a silly question, but how can I enable ProvideCurrentCpuInfo? I can't find it in config.plist
Any help please
AudioGod
Any help please
Make sure you are using OpenCore 0.7.2 and the quirk will be there.
Kernel->Quirks->ProvideCurrentCpuInfo
khalifa
Thanks for your reply.
now the installer starts and then I get black screen!
EDIT:
I'v managed to install Monterey successfully, I used latest version of WhateverGreen and Lilu and installation finished as expected!
Cosmin
This is laid out in the AMD_Vanilla GitHub Readme but I'd thought I'd post here too incase of any questions.
Patches are now universal across 15h, 16h, 17h and 19h by utilising the OpenCore Kernel Quirk ProvideCurrentCpuInfo
Make sure to enable this quirk or the system won't boot.
This quirks provides the kernel with the CPU frequencies for macOS to boot.
Core Count patch needs modified to boot your system. Find the three algrey - Force cpuid_cores_per_package patches and alter the Replace value only.
Replace:
B8000000 0000
BA000000 0000
BA000000 0090
Becomes:
B8 <CoreCount> 0000 0000
BA <CoreCount> 0000 0000
BA <CoreCount> 0000 0090
substituting <CoreCount> with the hexadecimal value matching your physical core count.
CoreCountHexadecimal
6 Core06
8 Core08
12 Core0C
16 Core10
32 Core20
So for example a 6 Core 5600X Replace value would result in these replace values
Replace:
B8 06 0000 0000
BA 06 0000 0000
BA 06 0000 0090
Note the 06 for the 6 Core CPU.
It's quite simple but if you've any questions on how to do this simply ask.
Enjoy,
Please tell what file (s) should I edit, where and how can I find algrey - Force and the others. Thanks
It's the first three patches in the plist.
Cosmin
I already use your entire EFI, modified with my MMIO and platform info, but doesn't work.
After reboot, install freezes at almost 3 percent, the computer only responds at forced shutdown...
Are you referring to the black screen with the Apple Logo and progress bar when you say 3 percent?
Cosmin
Ejh4286
Replace:
B8000000 0000
BA000000 0000
BA000000 0090
Becomes:
6 Core06
8 Core08
12 Core0C
16 Core10
32 Core20
Replace:
B8 06 0000 0000
BA 06 0000 0000
BA 06 0000 0090
Enjoy,
What is the hexidecimal for 24 core threadripper?
0x18
Open Calculator, switch it to Programmer mode (⌘ + 3), select "10", type 24, switch to "16" to get the hexadecimal value.
naresh
I'm getting below error: help required, thanks in advance
#LEB.LD.LF|IN] 01 ("'(null string)") <"]")
*LEB.B.SBS ISZ] 723512
#LEBIB: SHA]<14359Bcec12c90344c2dlb4bb60c3621e81109781>
#LEB.WL.PWLFNV1!1 Err(OxE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-AB80-FE41995C9F82
#LEB.WL.DT|!] Err(BxE) <- EB.WL.PWLFNV
#IEB.WL.PWLFRTCINONE]
#LEB.WL.DT|!] Err(BxE) <- EB.WL.PWLFRTC
#LEB.FS.AGSVHIRU]4BB59EBB-1EBD-34F2-B395-FC4CBA34BE23
#LEB.FS.AGSVHI!] Dk(D) <- BS.LocHB 964E5B22-6459-11D2-8E39-BBABC9697238
#LEB.FS.AGSVHIGVI!] Err (Dx3) D
#LEB.FS.AGSVHIGVI!] Err (Bx3)
#LEB.FS.AGSVHIGVI!] Err(Bx3) 2
#LEB.FS.AGSWHIGVI!] Err(Bx3)
#LEB.FS.AGSVHIGVI!] Err(Dx3) 4
#LEBIFMUFSV] RV 4BB59EBB-1E8D-34F2-B395-FC4CBA34BE23 Ox00000040
#LEB.LD.LKC|CFG](*\boot\\BootKernelExtensions.kc">
#LEB.LD.LF|IN] D1 (\boot \\BootKernelExtensions.kc"> ("O>
DC: Kernel patch 3 for kernel (algrey
_commpage_populate - Remove romsr - 18.13/10.14/10.15/11.0/12.0) is borked
Halting on critical error
m0>
I don't have these entries in my p.list, unless I am looking in the wrong area, as the first patches listed do not mention cpu anything . I'm on Big Sur at the moment (11.6.3), and have checked the option ProvideCurrentCpuinfo is active. Is there a specific area to look for these Algrey entries?
I don't have these entries in my p.list, unless I am looking in the wrong area, as the first patches listed so not mention cpu anything . I'm on Big Sur at the moment (11.6.3), and have checked the option ProvideCurrentCpuinfo is active. Is there a specific area to look for these Algrey entries?
It's the first 3 patches in the plist.
m0>
m0>
I just downloaded your p.list for the Asus board (I am using an Aorus x570 and 3700x), and looking for the entries mentioned in this thread, I do not see the data you mentioned that should be either altered or outlined in the 'Force cpuid' sections of your p.list .
See here,
m0>
yes, using binary did the trick on yours, but mine is not going to fly in its present state. It looks like I will have to start from scratch...
