EFI MONTEREY / RYZEN 7 3700X / MSI MPG B550 GAMING CARBON WIFI / RAM DDR4 32GB 3200GHZ / M.2 NVME SAMSUNG 500GB / SAPPHIRE Vapor-X Radeon HD 7970
saif5555
7
Usa
ryzen 7 3700x
Hi Dear
Please please please πŸ™πŸ™πŸ™ my friends I need EFI boot file Opencore for my desktop computer to install Monterey 12.1 Please help me My computer specification is below
πŸ€ M.B MSI MPG B550 GAMING CARBON WIFI
πŸ€ CPU RYZEN R7 3700X
πŸ€RAM DDR4 32GB 3200GHZ
πŸ€ GPU AMD RADEON SPPHIRE HD 7970 VAPOR-X
πŸ€ M.2 NVME SAMSUNG 500GB
πŸ€ WIFI CARD AX200
πŸ€ SOUND CARD ALCS1200A
The OP has been told that before as this is exactly the same post they have dumped in a few other threads.
To me it seems they are too lazy to undertake the research and effort required to create an OpenCore EFI folder for their system. They want someone else to do all the work for them.
Reactions: Tyoma
Hi Dear
From my understanding there are issues with MSI boards and Monterey. You should try making installer for Big Sur. If you have trouble understanding how to make your own EFI, there are plenty of people out there sharing their EFI, Look for an EFI with the same motherboard chipset, CPU core count and change the platform info to new numbers for your machine and start learning from there. I am still learning myself and I understand how frustrating it can be getting started.
Hi Dear
This EFI should get you going so you can start learning how to update and modify. I did all the kexts for your LAN and Wifi, but if one does not work, you would need to do more research. I set the platform info for you so all you need to do is make an Installer of Big Sur.
