Hi all
I'm pulling my hair out over this.
I have no ethernet connection when I get to the GUI and select Install. It loads all of the resources from the internet before the GUI (I can see what it is connecting to during the verbose loading screen)
These are my specs: X570 Tomahawk, RTX 3080 + RX 580, AMD 3300X and trying to install OSX Monterey. I tried older OS versions but I can't get them to the GUI installer.
Looked at the output text file and the LucyRTL8125Ethernet.kext for Realtek RTL8125 is injecting upon bootup (verbose text file output confirms this).
I've tried changing OSBundleRequired from Network-Root to Root in info.plist for the RTL kext.
My ROM is set to my MAC address and the LAN connection works in Linux (POP OS) and WIndows.
I've used multiple prebuilt binary editions of the kext from here (I can't seem to reply to the forum thread, even though I think it'll be my best shot at figuring out what's going on. ) https://www.insanelymac.com/forum/topic/304235-intelmausiethernetkext-for-intel-onboard-lan/page/6/
I cannot select IPCONFIG -M in the command line of the GUI installer and select the speed of the network interface - there is no network interface.
Thanks all for any input. I've searched multiple forums to try get a solution and I can't seem to find it.
38:654 00:041 OC: Prelinked injection LucyRTL8125Ethernet.kext (LucyRTL8125Ethernet.kext) - Success
