AMD Adobe Fixes
You mean like this :p Tested on PS 2020 (21.1.2) and a screenshot from FH4 :D
Run PS like this to get it working.
MKL_DEBUG_CPU_TYPE=5 /Applications/Adobe\ Photoshop\ 2020/Adobe\ Photoshop\ 2020.app/Contents/MacOS/Adobe\ Photoshop\ 2020
Alves
@Shaneee, yes! As I am new in this Code thing, what should I do? What is MKL_DEBUG_CPU_TYPE=5?
Thanks a lot!!
Yu32
Thanks a lot!!
First make sure Photoshop is closed.
Then Just copy the whole line:
Open Terminal and paste the command (and hit return if you need to). It will Launch Photoshop.
Yu32
For an equivalent fix for After Effects crashing when using camera track and mask tracking, I was able to get it working by launching from Terminal with this command:
MKL_DEBUG_CPU_TYPE=5 /Applications/Adobe\ After\ Effects\ 2020/Adobe\ After\ Effects\ 2020.app/Contents/MacOS/After\ Effects
binauraloptions
Hey everyone, I found this solution on a similar thread at github:
This solution was provided by user gasseluk and starts at boot (after login)
AGENT=~/Library/LaunchAgents/environment.plist
cat << EOF > ${AGENT}
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Label</key>
<string>mkl-debug</string>
<key>ProgramArguments</key>
<array>
<string>sh</string>
<string>-c</string>
<string>launchctl setenv MKL_DEBUG_CPU_TYPE 5;</string>
</array>
<key>RunAtLoad</key>
<true/>
</dict>
</plist>
EOF
launchctl load ${AGENT}
launchctl start ${AGENT}
binauraloptions
Has anyone ran Puget Benchmark for After Effects?
If anyone on amd-osx would kindly share their results, it'd be greatly appreciated. Plus it'd help all of us make sure our amd-osx machine is running adobe AE up to our systems capability. (I'm building an opencore hackintosh, will be done in about an hour, and will post my Puget Benchmark scores here shortly after that when I run it.)
Thanks
Yu32
Thanks
I tried running it but it gets stuck trying to pull system specs
Alves
So, every time I need to open Photshop, I needto copy this code in the terminal? And let the terminal open when I am using Photoshop?
Alves
Does anybody work with Adobe Premiere 2020? Premiere crashes when I use Warp Stabilizer. As soon as I put this effect in any clip, Premiere closes.
Thanks.
divarak
Thanks.
Hello, beside the warp stabilizer on your ryzentosh, did you experience another issue? Do you use plugins?
Regards.
divarak
Yu32
Thanks.
Most likely the same issue as Camera Tracker in After Effects and Liquify in Photoshop... try running Premiere from terminal with this command:
MKL_DEBUG_CPU_TYPE=5 /Applications/Adobe\ Premiere\ Pro\ 2020/Adobe\ Premiere\ Pro\ 2020.app/Contents/MacOS/Adobe\ Premiere\ Pro\ 2020
Yu32
You can use the following and put them on your desktop if you want to just double click on them to launch each application. (see attached)
Basically you created these by creating a plain text file and saving as filename.command
Then in terminal you execute the command "chmod +x filename.command"
And it will be a clickable shortcut on your desktop.
  • AdobeShortcuts.zip
Alves
Regards.
divarak
No, I didn't. I only have issue with warp stabilizer. I use Magic Bullet, but it work well.
fntzzz
Hi, if you want use Photoshop without worry about being offline, just put and replace host file that is attached into this post.
Download it, then Go to folder-> /etc
and paste replacing old one.
For me work without any problem.
  • hosts.zip
unknownanon
Thanks for the fixes running PS on 21.1.3 without a problem:D
code4power
Fix for Adobe Character Animator 2020?
@rajovo Can you upload the com.adobe.dvaaudiodsp.framework binary file?
manoueltiger
Hey shaneee !
Can you tell me if your Adobe applications work with big sur please ? :)
Thanks !
