- Joined
- Mar 13, 2020
- Messages
- 2,178
@Shaneee, yes! As I am new in this Code thing, what should I do? What is MKL_DEBUG_CPU_TYPE=5?
Thanks a lot!!
I tried running it but it gets stuck trying to pull system specsHas anyone ran Puget Benchmark for After Effects?
PugetBench for After Effects
Updated 9/21/2020. Want to see how your system performs in Adobe After Effects? Download and run our free public After Effects benchmark to see how your system compares to the latest hardware.www.pugetsystems.com
If anyone on amd-osx would kindly share their results, it'd be greatly appreciated. Plus it'd help all of us make sure our amd-osx machine is running adobe AE up to our systems capability. (I'm building an opencore hackintosh, will be done in about an hour, and will post my Puget Benchmark scores here shortly after that when I run it.)
Thanks
So, every time I need to open Photshop, I needto copy this code in the terminal? And let the terminal open when I am using Photoshop?First make sure Photoshop is closed.
Then Just copy the whole line:
MKL_DEBUG_CPU_TYPE=5 /Applications/Adobe\ Photoshop\ 2020/Adobe\ Photoshop\ 2020.app/Contents/MacOS/Adobe\ Photoshop\ 2020
Open Terminal and paste the command (and hit return if you need to). It will Launch Photoshop.
Hello, beside the warp stabilizer on your ryzentosh, did you experience another issue? Do you use plugins?Does anybody work with Adobe Premiere 2020? Premiere crashes when I use Warp Stabilizer. As soon as I put this effect in any clip, Premiere closes.
Thanks.
Thanks.
No, I didn't. I only have issue with warp stabilizer. I use Magic Bullet, but it work well.Hello, beside the warp stabilizer on your ryzentosh, did you experience another issue? Do you use plugins?
Regards.
divarak
YES PLEASE! It crashes with this logFix for Adobe Character Animator 2020?
