Ethernet Not Connecting Intel l211AT on ASRock X570 Gaming 4 - Monterey
OG Nerd
284
101
43
55
Missouri, USA
Ryzen 9 5900X
I see reading on SMALLTREEINTEL82576 github that there is an issue with some l211 NICS using the kext, it does not show connected nor pulling IP. I tried Intelmausiethernet.kext and it does not work. Anyone know of any work arounds or fixes? I attached the EFI in case there is something in there that I am doing wrong. I would appreciate any help.
MOBO: ASRock X570 Gaming 4
CPU: AMD Ryzen 5 3600
RAM: 16GB PNY RGB DDR4 3600
SSD: WDSN850 512GB NVME
WIRELESS: FENVI T919
OS: Monterey 12.01
Working - Everything except expected like sidecar, and the Intel L211AT NIC. (No intel wireless, just NIC)
It's an issue with Monterey. There's another kext but it's not reliable. Connection will drop randomly and breaks after sleep. I bypassed this and got a Type C to LAN adapter. Works native in macOS so no issues getting it to work.
Something like this, https://amzn.to/3pMjees
Reactions: t0nyruiz
I was gunna install a pcie rtl adapter but that might be a better option however. I did discover another issue, when I go to shutdown it reboots instead. Have you ever encountered that?
Unsure how the BIOS options will be on the Gigabyte board but to fix it on ASUS you need to set this,
Advanced -> APM Configuration -> Power On By PCIe -> Disabled
There may be something similar.
Reactions: LazyBayes
