Ryzen 5 3600X - Gigabyte X570 Gaming X - Upgrade From Big Sur to Monterey Help Please
OG Nerd
HELP! LOL!. I am trying to upgrade from Big Sur to Monterey Latest Installer but when I try to boot into usb or upgrade, it hangs and goes no further. I am having trouble understanding updating my AMD patches for Monterey. If someone could please point me in the right direction I would appreciate it. Everything is working fine in Big Sur. Below are my specs;
Motherboard: GIGABYTE X570 GAMING X
CPU: Ryzen 5 3600X
GPU: RX 570 8GB
RAM: 32GB OLOy DDR4 3600
NVME: 500GB WD SN850 & Sabrent Rocket 4.0 1TB (For Windows 11)
Opencore: 7.6
EDIT: Thanks to longcoming & Shaneee I am up and running Monterey 12.01! Big ups to you two! Below is my updated EFI (Minus Serial, UUID, Ect.).
OG Nerd
Did you swap the MTRR (PAT) patches around so you are using mine? If so switch back to algrey's and it'll fix that.
I didn't swap any out, I think it was after longcoming updated the CPU PATCH for me possibly. Not too sure... BUT, I did update my bios and I was able to boot right into my Monterey Installer usb immediately
I did not swap anything out, I think the sound started acting up after the updated CPU patches, not too sure.... But I upgraded my bios to latest version and was immediately able to boot into the Monterey USB installer so here is where we are currently... If this works, I will update the EFI, and if the sound issue persists, I would greatly appreciate a look at the patch you are speaking of.
OG Nerd
I got it updated to Monterey but the cracking/popping on the Display port is still there, I saw that there, attached is latest EFI, could you please check to see which patch is there? Thanks for all the help by the way. I could not of done it without ya.
OG Nerd
  • config.plist.zip
OG Nerd
