Problem description:
The system behavior has changed drastically after upgrading from 11.6.1 to 12.0.1, with system audio and DisplayPort no longer working, followed by kernel panic after couple minute after boot/login. It is also worth noting that macOS also kernel panic when I shut the computer down manually through the menu bar.
Everything was working perfectly prior to the upgrade, and I could not find any problems with the files in my EFI folder. It is worth noting that HDMI-output still works, but the screen flickers randomly when using HDMI (this happened in 11.6.1 as well, I have never tried to solve the issue since DisplayPort worked perfectly prior to the update).
Current Opencore version: 0.75
What I have checked/done:
CPU: Ryzen 5600X
GPU: XFX Radeon 5600XT
RAM: 2 x 16GB Corsair Vengeance 3600Mhz
Storage: Samsung 128GB SSD (for macOS)
Motherboard: ROG strix B550i
Help and advice are welcomed! This is my first post, please go easy on me...
- Applied latest AMD patches
- Changed the core count patch according to the instructions (5600X, 6 core)
- Set ProvideCurrentCpuInfo = True
CPU: Ryzen 5600X
