macOS Monterey Patches Released
Actually the problem is your motherboard, You need to roll back the firmware until you find a working version that lets Monterey install. There is a problem with MSI motherboards and any version of Monterey past Beta 3. As you are not using a 5000 series CPU you can fix it by doing the above.
Now only the beta1 can be installed. If I want to upgrade to beta10, I should roll back my motherboard's bios firmware version to find a compatible one?
yes do exactly that.
Tip - Start on the earliest revision and work your way up from there missing nothing in between And one will work.
Reactions: SuperY
Monterey RC 2 - Clover 5141 - Latest Gigabyte Bios F35d working great on my R5 3600 and X570 Aorus Pro Wifi. Have not check on board Ethernet as I have a pci Ethernet card (HP N360T works oob)
Thank you, the upgrade is done perfectly.
But software update can't find the RC update. Need other updates in config.plist?
Make sure the SecureBootModel is set to Default and your using version 0.7.4 of OpenCore
Reactions: SuperY
I'm using a LG 38" Ultrawide (https://www.lg.com/us/monitors/lg-38WK95C-W-ultrawide-monitor) with a resolution of 3840 x 1600 for programming at home.
I find it much more usable than the two 27" Thunderbolt displays I have in the office.
There is a lot of usage for that big of a screen, you can have 2 IDE or 1 IDE and the Documentation beside each other easily, and some shell on the other side.
Ryzentosh Mac OS Monterey 12.0.1 RC (21A558) OC. 0.7.4
Placa base GIGABYTE X570 I AORUS PRO WIFI
Procesador AMD Ryzen 9 5950X Vermeer 16-Core 3.4 GHz
Memoria G.SKILL Ripjaws V Series 64GB (2 x 32GB) SDRAM DDR4 de 288 pines
Almacenamiento SAMSUNG 970 EVO 2TB M.2 SSD
Tarjeta de video ASRock Radeon RX 5600 XT Challenger Pro OC 6GB GDDR6
Caja Cooler Master NR200 SFF
Fuente de alimentaciĂ³n Cooler Master V750 SFX Gold Full Modular
Buen
Buen dia si te funciona el bluetooth no lo he logrado funcionar
Hello everyone, I tried to install 12.0.1 full installer and I'm getting a firmware issue....error accourd while updating firmware...., Can someone advice me on how to fix this, I can install beta 1,2,3,4,5 & 6 but 9,10, and 12 I can't install
Could be your GPU at a guess as there’s no more support for anything NVidia in Monterey
Does the security update 11.6.1 can break my OC 073 version ?
Graphics: MSI Radeon RX 460
Hello,
Is there already a fix for MSI boards? I just stuck on installing the latest Monterey on my MSI X570 A-PRO
@misterrm That issue has been investigated for weeks but no fix was found. Currently the only options are sticking to Big Sur, downgrade the BIOS (if you're not already on Zen 3) or switch to another board.
Hello,
@p2mmao Not all MSI boards are affected by this issue
they said MSI B550M Motar WiFi is affected by this issue badly. Today I restore my MacOS to 11.6, and re-enable SIP, and received the 12.0.1 update, and let it downloaded and installed 12.0.1, after several reboots and about 45 mins, the machine entered the 12.0.1 without any difficulty, but 2.5G ethernet, Wi-Fi and BT still doesn't work
beta 12.1 Out! (AMD 6600 XT support added)
