I found it on this site: https://dortania.github.io/Getting-Started-With-ACPI/Universal/spoof.htmlHow did you try and spoof the device?
B0670000.Compare these two to the Sample config of the same version.OCS: No schema for ProtocolOverrides at 12 index, context <Quirks>!
OCS: Missing key ProtocolOverrides, context <UEFI>!
Ok, I'm at home so trying right now...Assuming the PCI path is correct that should work.
ACPI->Add: The 5th Entry isn't pointing to a .aml file and needs fixed.
Kernel->Add: The 3rd Entry is missing the .plist from the end of Info".plist"
I'm getting there...Assuming the PCI path is correct that should work.
I have just one problem left: still no metal in Big Sur. When I press spacebar to see a preview off a pdf file, it lags.
My System is in Dutch, I can translate if you want.What does System Information show for your GPU?
PAT patch? Don’t know. Where can I find that?Looks like it's all enabled correctly there. Which PAT patch do you have enabled?
