No problems here either with 0.7.4
hey guys, any special config you're using? because i'm on BigSur 11.6 working well, but when I restart to apply the update the system reboots on the beginning of the process..
Make sure your using the latest commit of OpenCore 0.7.4 and set the SecureBootModel to j160 to see the update and while it’s downloading go back into your Config.plist and change the SecureBootModel to Default and then just leave the install to do its thing.hey guys, any special config you're using? because i'm on BigSur 11.6 working well, but when I restart to apply the update the system reboots on the beginning of the process..
ok, i will try that now! thanks a lot!!Make sure your using the latest commit of OpenCore 0.7.4 and set the SecureBootModel to j160 to see the update and while it’s downloading go back into your Config.plist and change the SecureBootModel to Default and then just leave the install to do its thing.
Thank you so, so much! It worked out great, now i'm also on Beta 8.Make sure your using the latest commit of OpenCore 0.7.4 and set the SecureBootModel to j160 to see the update and while it’s downloading go back into your Config.plist and change the SecureBootModel to Default and then just leave the install to do its thing.
I have the same issue you got and similar hardware. How did you fix that?Wel... I can't update to Monterey... But I can log in to Big Sur with these patches. IDK what's wrong now.
EDIT: Nevermind, it's working now. Monterey fully functional.
I just restarted the full process downloading the update from 0 and disabled all the security options in BIOS that I was using for W11I have the same issue you got and similar hardware. How did you fix that?
Thanks but i fixed it with OC074 without changing a single thing inside my plist or bios lol...guess there's some unknown conflict for 073 and beta8I just restarted the full process downloading the update from 0 and disabled all the security options in BIOS that I was using for W11
Ooooohhhhkay. I'm skipping this one.Updated to Beta 9 on AMD with OC 0.7.4 no issues but lost Ethernet with smalltree again. So be careful if you rely on Ethernet.
you mean OC?Beta 9 is not broken.
Run your config through the validator.
you mean OC?
thank you, I will try thatYes. When you download OpenCore in a folder you will find ocvalidate. Drag and drop it in terminal then your config plist and hit enter. It will either spit out errors or nothing.
2021-10-12 18:02:03.008999 Checking For Resources...Yes. When you download OpenCore in a folder you will find ocvalidate. Drag and drop it in terminal then your config plist and hit enter. It will either spit out errors or nothing.
