Need Help,B550M Monterey beta8
mzfqy
5900x
I use b550m + 5900x + rx480 4g +oc0.7.4
It can work perfectly in MacOS 12 beta2 but don’t work later
  • Downgrade Bios Version to '7C94v12' (otherwise the installation will mostly render unsuccessful) (notice that, this means you cannot have and 5000 series processor, since they need a newer bios version to work)
if you need to compare efi:
and if you share more info about your specs like brand, bios version, etc, maybe people can help you more effectively!
i‘m not msi b550m。efi use oc-gen-x automatic gennerate and add cpur.aml
the brand is maxsun.
