Direct update to 12.0 from 11.6
soulblood
24
Hello, does anyone tried to direct update from big sur using the official updater? I have 0.7.3 running fine with 11.6 but the upgrade keeps looping/restarting....
Edit: i tried EFI from Shanee and still have the same symptom....and the new EFI also works find under 11.6
Do you have the latest kernel patches?
Are your kexts updated? I may be that you're using a version of Lilu etc that isn't updated for 12.x. The current versions should be.
I can't see anything out of sorts there. @AudioGod any ideas?
Stuck with this after updating from 11.6 to 12.0.1 OC0.7.4. Haven’t had any issues in 11.6
finally booted to monterey and then restarted. But now aftee selecting the drive from the boot picker. Its bootlooping back to MSI LOGO and then OC picker
