macOS Big Sur 11.6 update went smoothly
Cyberdevs
58
18
Ryzen 9 5900X
I just updated my Ryzentosh to macOS Big Sur 11.6 and the update went smoothly 🤘
I just haven't had the time to swap the GPUs so I'm still using my old R9 270X 🤪
Can the Big Sur 11.5 to 11.6 update be done easily with the "Software Update" function (exactly as if an actual Macintosh was being used, instead of a Hackintosh) ?
Or do you have to download the 11.6 OS, make a bootable USB key disk, etc. etc. ?
Just update and all will be just fine. There’s no need to make a bootable installer unless you just want to clean instal anyway.
Reactions: HackinHeimer
