-v so you can see where it halts if it still does. You'll also need to add a kext for networking. Add this to your EFI and config, https://github.com/Mieze/RTL8111_driver_for_OS_X/releases/download/2.4.2/RealtekRTL8111-V2.4.2.zip Thank you so much for the help. I booted it and installed Big Sur and everything is working. Now one thing is not working. Might be a bad idea do ask about this on the same thread but I will still do it. I can't seem to connect to my appleid. It says "Could not communicate with the server.". How would I fix this?Check the troubleshooting guide here, https://dortania.github.io/OpenCore...tion-begins-previous-shutdown-hpet-hid-legacy
hi, can you share your EFI folder, i have the same specification like yours, except for VGAThank you so much for the help. I booted it and installed Big Sur and everything is working. Now one thing is not working. Might be a bad idea do ask about this on the same thread but I will still do it. I can't seem to connect to my appleid. It says "Could not communicate with the server.". How would I fix this?
| Motherboard: | CPU Type | HexaCore AMD Ryzen 5 3600, 4200 MHz (42 x 100) |
| Motherboard Name | Gigabyte B450M Gaming (2 PCI-E x1, 1 PCI-E x16, 1 M.2, 2 DDR4 DIMM, Audio, Video, Gigabit LAN) | |
| Motherboard Chipset | AMD B450, AMD K17.7 FCH, AMD K17.7 IMC | |
| System Memory | 16328 MB | |
| DIMM3: GeIL CL18-22-22 D4-3600 | 8 GB DDR4-3600 DDR4 SDRAM (18-22-22-42 @ 1801 MHz) | |
| DIMM4: GeIL CL18-22-22 D4-3600 | 8 GB DDR4-3600 DDR4 SDRAM (18-22-22-42 @ 1801 MHz) | |
| BIOS Type | AMI (03/29/2021) | |
| Display: | Video Adapter | NVIDIA GeForce GTX 650 Ti BOOST (2 GB) |
