stuck at apple logo and progress bar
Chouko
Ryzne 3600
Every time i try to boot from my USB it gets stuck on the Apple logo and progress bar
My hardware
Ryzen 3600
Rx 570 8gb
Gigabyte b450m ds3h
16 GB ram
So now it boots to the massive lines of text, here is the files if you want to see them. If you want to know something more i will give you more info if you need some. New to this and want to learn it.
The lines of text are the system booting in verbose mode. Useful for debugging. If it's getting stuck somewhere snap a picture and upload it so we can see the issue.
Reactions: Chouko
hope this is what you are looking for. I'm sorry for the low quality. If you cant see what you need tell me where i should take a picture so it can focus better.
Reactions: Chouko
Thank you so much for the help. I booted it and installed Big Sur and everything is working. Now one thing is not working. Might be a bad idea do ask about this on the same thread but I will still do it. I can't seem to connect to my appleid. It says "Could not communicate with the server.". How would I fix this?
hi, can you share your EFI folder, i have the same specification like yours, except for VGA
Motherboard:CPU Type HexaCore AMD Ryzen 5 3600, 4200 MHz (42 x 100)
Motherboard Name Gigabyte B450M Gaming (2 PCI-E x1, 1 PCI-E x16, 1 M.2, 2 DDR4 DIMM, Audio, Video, Gigabit LAN)
Motherboard Chipset AMD B450, AMD K17.7 FCH, AMD K17.7 IMC
System Memory 16328 MB
DIMM3: GeIL CL18-22-22 D4-3600 8 GB DDR4-3600 DDR4 SDRAM (18-22-22-42 @ 1801 MHz)
DIMM4: GeIL CL18-22-22 D4-3600 8 GB DDR4-3600 DDR4 SDRAM (18-22-22-42 @ 1801 MHz)
BIOS Type AMI (03/29/2021)
Display:Video Adapter NVIDIA GeForce GTX 650 Ti BOOST (2 GB)
thank you
or maybe someone can give me EFI folder to start, with my PC specification, so i can try installing and see if there are any errors.
I am very new in this, but i want to have macOS installed in my PC :)
thank you
