BigSur 11.5.1 Installer not starting; used Dortania-Guide
maxproof
6
AMD Ryzen 5 5600X
Hey everyone,
I wanted to build a Hackintosh for a long time now and started today. I followed the OpenCore Guide (twice, for good measure). The installer doesn't start. Tried troubleshooting accoring to recommendations but didn't get any further.
Someone willing to have a look at my EFI/bootlog? Getting pretty frustrated tbh.
Best regards
Max
Above4G decoding active/deactivated makes no difference
ResizeBAR is deactivated
Try with this.
Try with this.
Hi, thank you very much for the reply. Sadly it doesn't work. It loads OpenCore, shows what's been loaded and then reboots 1-2times until it get's stuck on this screen.
The EFI you provided doesn't log is that right?
Any ideas? Thanks everyone in advance.
Remove the CPUR SSDT and test. Yes it doesn't need to log as the issue is after OpenCore.
.. no more restarting, but getting stuck here:
with pcie 3.0 is get this .. any clue to what's causing the problem?
nvmefix.kext caused the problem! Now it's installing!🤷‍♂️:)
