Edit:
Seems like something is booting now, I changed the driver of "hfsplus.efi" to "hfspluslegacy.efi", and not something booted and asked me to hit enter for "(external) dmg", which I did so and now I get a blank screen and computer is restarts and goes through a loop process. I also updated the log file below.
I get the above screen, when I click on "boot (external) dmg", I get few texts of lines then the computer goes into a complete blank screen, then the computer restarts into a loop and goes back into the same menu.
Followed all the steps from the OpenCore guide for AMD build.
What going wrong here?
Desktop Build:
CPU: AMD FX 8350
Motherboard: ASRock 970 Extreme 3
GPU: Readon WX 2100
USB Boot Drive: 250GB SSD Kingston
MacOS: Big Sur
Here is a video of what happens during the boot process:
Here is the EFI folder for anyone that want to investigate:
https://drive.google.com/file/d/199ZP8iZADenbdhUZ9ZsJLHKYM1C1dADq/view?usp=sharing
Here is the ".txt" file which OpenCore logs data into the boot partition:
https://drive.google.com/file/d/1MVfxq_YaVC9xwt0nH_v6iPza0qhRh4Jy/view?usp=sharing
Edit, I solved the problem, here is the link how I solved it:
Desktop Build:
CPU: AMD FX 8350
GPU: Readon WX 2100
MacOS: Big Sur
