[Pre-Release] macOS Monterey
I am using the exact same EFI located in my EFI partition on my nvme drive. Monterey and windows 11 boot fine.
on your big sur efi config, try to snapshot the big sur oc folder using propertree or other plist editor
Big Sur and Monterey both use the same EFI. Monterey boots, Big Sur stuck at Apple logo. I’ll boot -v later and see what’s going on.
ok ··
(y)
Reactions: elixir
try this patches in USB for Monterey and Big Sur, you should be able boot both OS, of course on your own risk.
this monterey pacthed i dont see the core count
CoreCount = Your CPU Physical cores in Hex.
  • 6 Core = 06
  • 8 Core = 08
  • 12 Core = 0C
  • 16 Core = 10
  • 32 Core = 20
  • 6 Core = 06
  • 8 Core = 08
  • 12 Core = 0C
  • 16 Core = 10
  • 32 Core = 20
sorry, edit: my system do not accept the above entry, i have XLNC ----- #2 error during boot.
what i did is copy paste the code from XLNC for me to able to boot Monterey and Big Sur ---> this is for savage001 to trial if he can boot same as mine :)
the purpose of the experiment using corecount is to trim down the patch entries,
please refer to this post on the patch with corecount: https://forum.amd-osx.com/index.php?threads/pre-release-macos-monterey.1841/post-11585
yes, with your plist, work to boot on my fx machine, but got wrong cpu frequency 😅
maybe in your bios settings for the CPU / mem frequency settings? it would be safe and check if AUTO can help :) ive heard also that overclocking may affect the frequency display
Thanks I’ll give these a try tomorrow. Would be nice to boot both BS and Monterey until Monterey is released properly.
No, i don’t use other setting bios for processor and memory, your config still same result with my build before about montery prepatched error cpu frequency 😥
have you updated your bios mobo with the latest version?
What are the differences between these 2?
The one labeled Big Sur only booted Big Sur but the one labeled for Monterey booted Both BS and Monterey. Thank you.
monterey: new patch + xlnc --#2 ---> this is to boot Monterey and Big Sur, select this as your primary boot in bios
Big Sur: Big Sur patch ---> this will be your backup just incase you cannot boot on Monterey, select this as secondary boot in bios.
can you confirm again that this is working for you?
thank you to all who made the patches available to us, cheers!
monterey: beta1 patch + xlnc --#2 ---> this is to boot Monterey and Big Sur, select this as your primary boot in bios
Big Sur: Big Sur patch ---> this will be your backup just incase you face some problem on Monterey, select this as secondary boot in bios.
I can confirm the Monterey.plist is booting Big Sur and Monterey and I’ll have to assume Windows 11 as well. Monterey boots way faster than Big Sur.
Reactions: elixir
im so glad to hear it works for you :)
I thank you all who made the hardwork on the AMD patches
Reactions: AudioGod
Yes very thankful to all that made it possible.
Can people please share screen shots of the energy saver window in Monterey on AMD. My options seem limited.
Reactions: AudioGod
i can fix all that for you if you want?
Its off topic for this thread so just make a new thread concerning power saving features and tag me and il come and help. :)
Reactions: FREE1 and elixir
Any new about smalltree kext?
