Let's begin with a Big Thanks to AudioGod, you rock!
I spent a couple of days looking for a preconfigured setup with no luck until I thought what the heck... using the work done with aorus x570 pro (link below) Aorus Master x570 worked out of the box with his EFI, adjusted sn and uuid and added agpmod=pikera for my radeon vii.
Build Spec
forum.amd-osx.com
Build Spec
- CPU: Ryzen R9 5950X
- Motherboard: Gigabyte AORUS X570 Master rev 1.1/1.2 - BIOS F33
- RAM: 32GB G-Skill Trident 3200Mhz C16 (XMP)
- Graphics: Radeon VII
- NVMe: Samsung 970 EVO 500GB/WDBlack 850sn 1TB
- PSU: EVGA 850
- Installed Operating Systems: Big Sur 11.4 - Windows 10 Pro
- Bootloader: OpenCore 0.7.0
@ufotom If you are using SMBIOS MacPro7,1 then try this EFI (Just add your details to the Config.lPlist) and if you’re not using a X570 Pro or Ultra then disable the USBMap.kext https://forum.amd-osx.com/index.php?attachments/gigabyte-x570-pro-7-1-069-efi-zip.3182/ If you’re using SMBIOS...
