Solved Help me please (not booting after update)
BomBayGini
56
11
Ryzen 9 5900X
i have done the bigSur 11.4 update from the settings of the pc and its not booting now.
this is what it looks like, please help me if you know to fix this <3.
Did you ensure you had the latest patches and kexts before updating?
No I did not updated any kext and patches, what can I do now to fix that?
This is my EFI i tried to update the opencore files its brokes also the bootloader. i dont know how to fix it, if you can help it would me much appreciated.
It was a bit outdated. I've updated it to OC 0.7.0 and updated Lilu and it's accompanying kexts. Also I double check the kernel patches. Give this one a go,
works like charm thanks man !
can you tell me please what have you updated ?
i want to know for the next time it will do an automatic update.
I updated OpenCore to 0.7.0 Release, Updated all the Acidanthera kexts and fixed some settings in the config.
Reactions: Exxxx
you are the best ! thanks a lot!
so in another case of MacOS update i must to update the opencore and the kext also?
Reactions: Shaneee
Not in all cases but in some yes.
I'd uncheck the option for automatic installation of system updates. First check here / other hackintosh forums if there are problems with an update.
Before updating use either OpenCore Configurator or Hackintool to see if the Kexts need updating.
As you can see, my kexts are out of date. No problems for 11.4 but prior to 11.5 (or 12.0) I will for sure be updating the kexts. Too many times I have been stung by the "if it works, don't change it" philosophy; It's always a 50/50 gamble. The same goes for OpenCore, especially on AMD systems. I went two system updates without having to change anything (boot loader, kexts) yet 11.4 forced me. Thank God for System Restore.
