Yes the other version to get would be a BCM94360CS2 and a pcie adaptor.Is there a PCIe version of this? I have an extra M2 but not sure how I would manage the antenna.
So bluetooth will work but Airdrop won't if I use your plist as a template? I'm a little confused between the two statements, sorry I'm dense today. I was aware you had a different board - comparison was what I was after - so thank you! I took a look and you're not doing anything special to inject those kexts.
I'm using an iMacPro1,1 SMBIOS. I see you're using MacPro7,1. Does this matter or will it not get me any farther?
Thanks again.
AirDrop does not work with the Intel wireless card and kexts Full Stop, The Developer of the kext may implement it down the line but for now AirDrop and Intel wireless = No
To use 7,1 you would need to sign out of your icloud account, generate new smbios details and then sign back in after you have swapped over and restarted With a NVRam Reset in between.
