[HELP] Clover Configurator Don't Save Setting
vuakang
Hi guys , I tried changing a few things in the boot and system parameters and then saved but when rebooted everything went back to normal.
how to fix it can anyone help?
System Info
CPU : AMD Ryzen 3600X
RAM : 32Gb
GPU : Nvidia GTX 1080
Mainboard : B450M Steel Legend
OS : Mojave 10.14.6
We don't really support Clover anymore but it may be a NVRAM issue. Make sure your changes are still present in your config and run this in Terminal, sudo nvram -c
vuakang
oh god sudo nvram -c
terminal error clearing firmware variables :(iokit/common) not permitted
Boot using Single User Mode and execute the command. From Clover add -s as a boot arg then during boot you'll be able to enter the command.
