unable to enter the system after replacing the motherboard
dmls
52
Ryzen5 5600x
Hello everyone, I have a problem. After replacing MSI A320 with MAXSUN b550m, Big Sur can't boot normally. I have added ACPI according to the 'OpenCORE Install Guide', but it doesn't work
Switching from A320 to a B550 you basically have to redo your entire EFI
ACPI paths are usually different between different models with the same chipset, sometimes even between different BIOS versions. Same for USB ports.
CtlnaAHCIPort.kext and XHCI-unsupported.kext are not needed on B550.
"Ctlnaahciport. Kext" and "xhci unsupported. Kext" were added later in the test. He was like this when he didn't join again
I downloaded a MSI b550m EFI from GitHub, and the same problem occurred
Then verify your BIOS settings
BIOS settings is ok
  • CSM: disabled
  • Fast boot: disabled
  • Above 4G decoding: enabled
  • RezisableBAR: disabled
With such an old card better disable Above 4G Decoding and add the npci=0x2000 boot arg
It may not work
You need to recreate your EFI folder obv... it's a different MB.
Try adding in your efi folder: SSDT-AWAC.aml
Erm…….
Thats not going to work as you can’t use a Intel ssdt for a legacy real time clock fix on a AMD setup.
That’s just a NoNo I’m afraid.
Erm…….
Erm... I have an amd setup and that aml works perfectly for me..
It’s not doing anything I bet. It’s just sitting in There. Check your io reg and see for yourself.
your using a SSDT that I promise you is doing zero, it’s made for Z390 and Z490 boards. Even the code inside the SSDT points to Intel pathing.
Reactions: Shaneee
Kkk
