laptop R5-7535HS stuck on "[EBILOG:EXITBS:START]"
asdf123
笔记本电脑R5-7535HS卡在“[EBILOG:EXITBS:START]”上,已添加MMIO白名单
  • opencore-2024-04-18-080549.txt
The GPU in your laptop isn’t supported in macOS.
Your laptop uses AMD Radeon™ 660M GPU.
asdf123
macOS 不支持笔记本电脑中的 GPU。
您的笔记本电脑使用 AMD Radeon™ 660M GPU。
Thank you for your reply. I have changed the graphics setting to MSHybrid mode in the BIOS. I added SSDT-GPU-DISABLE.aml to ACPI and added the -wegnoegpu to boot-args, but it's still stuck at the EB screen. Here are the specs of my mainboard and RAM configuration.Could it be a BIOS settings problem? I'm unable to disable vt-d, csm, and fast boot on my mainboard, and only secure boot can be turned off.
  • opencore-2024-04-18-120115.txt
