Config.plist wrong?
Edwin
Hi guys, I accidentally replaced an old config.plist with my current one (I forgot to make a copy, how stupido I can be) and now Monterey won't boot. Any thoughts/help?
Hardware: Mobo Asus Prime X470 Pro, GPU AMD R9 390, CPU Ryzen 5 3600 6-core.
Greetings from the NL
Attach the full EFI and I’ll make sure it’s all up to date.
Edwin
Edwin
Here you go. I have no idea what was going on with your kext folder so I've removed the unnecessary kexts and added RestrictEvents into the config.
Edwin
Hi Shaneee, nothing but the Apple logo when booting☹️
Add -v to the boot args and see where it's halting.
Edwin
This is the screen when booting.
Replace config with this one. Forgot to check the patches and you still had the old ones :p
  • config.plist.zip
Edwin
Edwin
Edwin
I'm guessing your PCI path for the GPU is wrong. Try with PciRoot(0x0)/Pci(0x3,0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0) or check with gfxutil or Hackintool.
Edwin
This is my location path:
PCIROOT(0)#PCI(0301)#PCI(0000)
ACPI(SB)#ACPI(PCI0)#ACPI(GPP8)#ACPI(X161)
ACPI(SB)#ACPI(USBX)#ACPI(GPP8)#ACPI(X161)
Edwin
Internet is also not working.
LAN won't work as SmallTreeIntel82576 isn't working on Monterey. You can use the alternative AppleIGB or AppleI2xx but it's not very reliable. The other options are native WiFi, or a USB to LAN adapter.
As for the GPU path that's not OpenCore compatible. I've made a short video on how to get it with Hackintool,
Edwin
So, back to Big Sur maybe?
That's entirely up to you. I got a USB Type-C to 2.5GB LAN for £17.99 on Amazon. Works OOB on macOS, Windows and Linux. There's standard USB ones too if you don't have Type-C on the rear IO. Works a treat :D
Edwin
Than it’s back to Big Sur. I have absolutely no budget/money to spend on hardware. I live from a part time salary. All the money goes to food and rent☹️ This pc I got is from a friend of mine who died a couple months ago.
RyzeCooker
Your original post said "now Monterey won't boot" So you had it working before? Or just that the upgrade didn't work?
