    Votes: 12 75.0%
    Votes: 2 12.5%
    Votes: 2 12.5%
  • Total voters
    16
  • Poll closed .
errevi
I had a similar problem and was able to install a few days ago, here is my EFI in case it helps. you need to change the core count from 16 to 12 (10 to 0C for your CPU) in the kernel patches (I also have a few Bluetooth kexts that you may not need)
Many thanks Julian, with your EFI I could start the installation
Darkpulse
Hi,
Just have made a fresh installation to 13.2 with OC 0.8.8.
Everything is working well except :
- BT & Wifi ( I use an USB Dongle for Bluetooth > iogear GBU521 )
- Camera continuity with iPhone ( black screen output )
I still noted a performance decrease based on my previous Monterey results ( Around -10% for CPU and -20% for GPU ) :cry:
For anyone want to use my EFI files ( at his own risks ) for the Aorus X570S Pro ( Bios up to date ), please find attached file.
  • EFI_X570S.zip
svan71
Hi,
Hey, what app did you use to map USB ports, as the ports on the X570S PRO AX are different.
Darkpulse
I used " HackingTool "
svan71
Darkpulse
Anyone experiencing difficulties like me with the new 13.3 update ?
I got stuck on boot, no bios or Opencore changes meanwhile.
Are you using the latest AMD Kernel Patches? A 4th CPU patch has been added to get Ventura 13.3 working.
Darkpulse
Indeed I have not noticed that kernel patches has changed for 13.3, thanks.
I made the update in my config.plist but without success. Same thing, boot freeze at the same step.
Darkpulse
Everything is now back to normal. I successfully updated to 13.3. I redo the kernel patch, I maybe had make a mistake the first time.
I had to delete the "APPLE" folder in the EFI and re-download the update package because I kept got a kernel panic.
Galve2000
I've been away for a few weeks so I'm a bit behind.
have you gotten Continuity Camera to work in Ventura on AM4.
from the 7000 testing thread it looks like Continuity Camera is working.
is this also true for AM4?
Darkpulse
Continuity Camera is still not working here with X570 and 13.3.
it's a shame, that's function could be very useful for me
Yes it works on AM4. Build in signature and iPhone 14 Pro Max. Enjoy the RGB fan :LOL:
Ezaul
Patches are now universal across 15h, 16h, 17h, and 19h by utilizing the OpenCore kernel Quirk ProvideCurrentCpuInfo. OpenCore 0.7.1 or newer is required.
Make sure to enable this quirk or the system won't boot.
Note for Zen 4: Zen 4 (Ryzen 7000) requires patching for IOPCIFamily.kext.
This patch is enabled by default. Please ensure that you've added it to your current config for Zen 4 stability. This patch also allows MSI A520, B550, and X570 boards to boot macOS Monterey and newer.
Core Count patch needs to be modified to boot your system. Find the four algrey - Force cpuid_cores_per_package patches and alter the Replace value only.
macOS VersionReplace ValueNew Value
10.13.x, 10.14.xB8000000 0000B8 < Core Count > 0000 0000
10.15.x, 11.xBA000000 0000BA < Core Count > 0000 0000
12.x, 13.0 to 13.2.1BA000000 0090BA < Core Count > 0000 0090
13.3BA000000 00BA < Core Count > 0000 00
From the table above substitue < Core Count > with the hexadecimal value matching your physical core count. Do not use your CPU's thread count. See the table below for the values matching your CPU core count.
Core CountHexadecimal
4 Core04
6 Core06
8 Core08
12 Core0C
16 Core10
24 Core18
32 Core20
So for example, a user with a 6-core processor should use these Replace values: B8 06 0000 0000 / BA 06 0000 0000 / BA 06 0000 0090 / BA 06 0000 00
6R23MeCe
As @Edhawk pointed out, I guess you may not set algrey - Force cpuid_cores_per_package for 13.3 correctly (I just met the exact issue as you, and was able to solve it by adding algrey - Force cpuid_cores_per_package for 13.3).
Ref
6R23MeCe
I have successfully upgraded to Ventura 13.3.1, just in case this EFI helps
  • EFI-Ryzen-5950X-X570-PRO-WIFI-OpenCore-20230413.zip
svan71
Base 074 updated to 091 with Kernel patch. Still requires CPU core count to be set for your CPU. This is set for 8 core 5700x
  • Gigabyte X570 Pro 7,1 091 EFI.zip
Pabo
Perfect, installed without any problems. Thanks, good work (y)
