- Joined
- May 2, 2020
- Messages
- 2,394
Monterey will work with an older version of OpenCore. Support started with OC 0.7.4 if I recall correctly. So any OC release since 0.7.4 should work.
You would have been better served running a clean installation of Windows 10 and then using a third-party application (PC Transfer Tool or similar) to move/clone your Apps etc from your old drive to your new drive. Microsoft has a built-in option for apps downloaded from the Microsoft Store that will do this but I don't recall there being an option for moving/cloning other applications.
This page may shed some light on what you are facing.
Safely Move Installed Programs to Another Drive in Windows 10 & 11
Here’s a guide about how to move installed programs to another drive Windows 10 and 11 without unloading and reinstalling the Apps.
www.diskpart.com
