zxc2689963
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
  • EFI-2023-10-5.zip
Solution
Panic from Monterey 12.6
zxc2689963
I have changed the ACPI file to my coustomized USB. But still get a forbidden icon after USBMS identifiers non-unique
It may be that the USB controller of Ryzen 7 6000 has compatibility issues and you cannot install it, but you can start the system installed on the hard disk and then add the old version of GenericUSBXHCI.kext and use it
redhorse1990
Is there any instructions to install the system from hard disk?
The two screen images you posted show different issues.
The first is a common issue where the laptop has stalled at the PCI Configuration Begins stage. There are a number of issues that can cause this KP. Ther are as many fixes too. See the OC Troubleshooting page linked below.
The second image may be related to the above, as it is an RTC related kernel panic.
You need to add the ncpi=0x3000 boot argument if you can't enable Above 4G Decoding in your bios.
If you enable Above 4G Decoding in your bios, GPUBars option becomes available, usually, and should also be enabled. Then and only then do you change ResizeAppleGPUBars to '0'. If you don't have the GPUBars option enabled in your bios, then leave the setting as '-1' in your config.plist.
Some laptops don't have the BIOS option and it's hard enabled.
Where is the kernel panic?
The first screenshot show the PCI Configuration Begin issue.
The second screenshot shows the RTC read failure
redhorse1990
With zxc2689963's newly provided EFI, these KP has been resolved. But it comes with another KP following of USBMS identifiers non-unique with a forbidden icon. It may be related to USB controller of Ryzen 7 6000 has compatibility issues. But I have no idea how it could resolve. Would you kindly provide some help? Thank you
  • EFI (2).zip
zxc2689963
What version of BIOS are you using? Zen 3+ architecture notebooks have added the AMD USB4 function. The IOUSBHostFamily driver cannot recognize AMD USB4. The USB4 function can be added in the BIOS update. Try downgrading to the lowest version of the BIOS. If it still doesn't work, there is nothing you can do. You can only install MACOS on another computer, then remove the hard drive and install it in the laptop
redhorse1990
My bios version is KFCN27WW。 Which bios version should I downgrade? And is there any possible way to downgrade legion bios? Thank you.
redhorse1990
Is there anyway to fix the issue of IOUSBHostFamily driver not recognizing AMD USB4? I think this issue leads to the forbidden icon after the bios hands the use controller to usb boot loaders. Thanks
Short of disabling the ports during installation, I am not aware of a fix for the USB4 ports.
redhorse1990
Would IOUSBHostFamily driver support Zen 3+'s added USB4 in near future? Thanks
No, Apple won’t be adding any additional drivers or driver updates to macOS for USB4, as they have only implemented Thunderbolt/USB4 on their Apple Silicon systems.
The end of support for Intel systems in new macOS releases could come with the next major release, next September. If not it will definitely happen the next year. So Apple won’t be providing any new features, drivers or significant improvements for the last of the Intel systems they currently support. They want everyone to move to their Apple Silicon systems, so additional support for the dying Intel systems is probably the last thing they intend or would want to do.
zxc2689963
You can try to use the UniversalAMDFormBrowser tool to close projects related to USB4. Your laptop model should not have USB4, but I saw the NHIO code in the DSDT. If you still can't solve the problem, you can only wait until the core graphics card of ZEN3+ can drive it. It may be possible by then. Someone knows how to deal with this problem
  • Smokeless_UMAF-main.zip
Jo-Toku
Anyone using the AX200ngw wifi card? The Wifi works, however not the Bluetooth. Or is the AX210 is the one recommended under Sonoma?
Yes, I have an Intel AX200 WiFi/BT card installed in my Asus X570 system running Sonoma. Both WiFi and Bluetooth are working perfectly.
I have an Intel AX210 in another Hack and that works great too. This is the better option for macOS if you have WiFi 6 network.
Jo-Toku
Both ax200 and 210 have spotty Bluetooth performance on on the Legion 5. They work but, meh. The Broadcom is a lot better, but the Wifi is pain getting it working on this machine. Wifi on the intel is very good however.
AJCOSTA
I have a ryzen 5600h and rx6600 m.After the installation when I boot it gets stuck showing iokitdeamon kernalmanager stall iGPU
