zxc2689963
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
  • EFI-2023-10-5.zip
Solution
Panic from Monterey 12.6
zxc2689963
The screen image above shows that one of your SSDT's is causing a kernel panic, i.e. SSDT-USB-Reset.aml.
See screenshot below.
Try removing the SSDT from your setup and see if that helps.
You should also delete the USBInjectAll.kext from your /EFI/OC/Kexts folder and config.plist, as you don't need it with an AMD system. It is set to work with Intel USB controllers, not AMD USB controllers. The Kernel > Quirks > XhciPortLimit entry will still work without this kext.
Try this revised EFI-3 attached below, see if this helps. It incorporates the changes recommended above.
Try the revised EFI on a spare USB pen drive.
  • EFI-3.zip
redhorse1990
Thank you for your fix. The original problem is resolved but it stuck at another place. Is there any fix for that?
redhorse1990
You can use USBToolBox to customize the USB port, and there are many tutorials available online
Sorry, still have no idea how could I make it. This is my USB configuration files. Would you kindly make changes for me?Thanks
  • UTBMap.kext.zip
  • DSDT.zip
We can’t fix or configure your USBMap.kext, as we can’t test 5he ports to see what is wrong. You are the only person who can do that.
Try using a different USB port when you boot into the installer.
redhorse1990
I have tried your EFI-3.zip in both use ports. But still gets the same error, it successfully handled ACPI Error, but it stuck at SMCTRC: start,the forbidden icon is the KP of another EFI provided by zxc2689963. I still haven't figured out both fixes. Thanks
The screen image that ends with the SMCTRC: Start text doesn't contain an error or Kernel Panic information. So I have no idea what that termination/stop point is caused by.
Does the system automatically reboot at that point, or just sit there with no changes?
Have you tried leaving it at that point for 20-30 minutes to see if it progresses slowly?
redhorse1990
No, I didn't restart. I would try to wait another more 20-30 minutes to see whether it went through.
redhorse1990
I had another problem, do I need to add npci=0x3000 from boot-args and set ResizeAppleGPUBars to 0. Some people suggests that change, while others suggests not. I am not very sure. Thank you
You need to add the ncpi=0x3000 boot argument if you can't enable Above 4G Decoding in your bios.
If you enable Above 4G Decoding in your bios, GPUBars option becomes available, usually, and should also be enabled. Then and only then do you change ResizeAppleGPUBars to '0'. If you don't have the GPUBars option enabled in your bios, then leave the setting as '-1' in your config.plist.
redhorse1990
I have tried various fix. By setting ncpi=0x2000 and ResizeAppleGPUBars to ‘-1’ I can go to the farest. I am having another stuck at here. Could you find any related KP?Plus zxc’s EFI patch could go further but got a forbidden icon after USBMC identifier non-unique. Is there any related KP on that? Thanks
