Need more tester for Navies 22 Card.
I'm all for support being given by the team on Telegram but the forums here are indexed. If someone searches for any issues they're having it'll come up on Google etc. If a solution is posted it'll help users with a similar problem :)
I would help here as well if my permission to edit my messages wasn't denied for some odd reason, these types of shadow bans are the worst.
AndresZeroCross
Sometimes when i change connection with DP, i got kernel panic. The configuration is still same but i got kernel panic with DP. When i reboot then no kernel panic but stuck like previous image. We can assume 7 try reboot will give 4 kernel panic. But with HDMI it always stuck. Here is the picture of kernel panic. I can see NootRX.kext being part of kernel panic problem.
Your macOS version is too old.
AndresZeroCross
There's no shadow ban. I don't know what's going on with the edit permissions. They're enabled for everyone to edit their own messages.
AndresZeroCross
UPDATE: Good news. Finally Navies 22 got supported by Noot Team. and congratulation for all of them.
But this pictures show 13.6, so it's not about broken patch right?
silkroadonsale
Well it certainly doesn't work for me.
13.4 in the OP screenshots.
it's work perfectly good for the patch. I just update to 13.6.1 yesterday. didn't change anything
AndresZeroCross
May i know all of your kext inside kexts folder. I am afraid this is about kext compatiblity
silkroadonsale
AndresZeroCross
it's all up to date version.
I didn't see any different with mine. even with Lilu.kext, VirtualSMC.kext, Nootrx.kext, AppleALC.kext, i still stuck can't reach desktop.
I hope this is not about Power Color VBIOS problem. I know several people using Power Color RX 6600 varian and 6800 variant without problem in hackintosh. Power Color RX 6700 XT should same :(
No, it failed to apply a patch. Are you 100% sure it's not some older version?
AndresZeroCross
I am pretty sure. I boot with Ventura 13.6 Installer. All kext is updated
silkroadonsale
AndresZeroCross
I mean get the latest NootRX to check out again. if it work or not.
It's latest commit, i got the Artifact from this commit. It's should be the latest version
AndresZeroCross
It's boot fine with disabled NootRX.kext. You can see, it's Ventura. Not old version
