Where do you put OC with Big Sur? There’s no EFI volume
rajovo
I can boot BS without any issues with OC on flash drive but where do I put OC on the Big Sur drive? My Catalina drive has an EFI volume, BS does not. Do I just create it? Thanks!
It will do. Post a screenshot of diskutil list and I'll point it out for you.
MadMax1998
In Terminal, type
diskutil list
and look for the volume named "EFI" that sits on your Big Sur disk. Note the disk number next to the name. Then mount it:
sudo diskutil mount diskXsX
(where X is to be replaced by the proper digits)
Look in Finder; the EFI volume should be there now. Copy your EFI folder from the USB to there --> done.
