Waves Plugins Fix
Driftwood
Get The Following Problematic Plugins From Waves Working On AMD.
Perl:
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/CLA\ EchoSphere.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/CLA\ EchoSphere.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/CLA\ MixDown.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/CLA\ MixDown.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Butch\ Vig\ Vocals.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Butch\ Vig\ Vocals.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/EddieKramer\ BA.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/EddieKramer\ BA.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/IR-L.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/IR-L.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-EQ.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-EQ.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-TripleD.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-TripleD.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-Distortion.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-Distortion.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-ToneShaper.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-ToneShaper.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MetaFilter.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/PuigTec.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/PuigTec.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/PuigTec.bundle/Contents/MacOS/IR_Calc.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/PuigTec.bundle/Contents/MacOS/IR_Calc.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Scheps\ Omni\ Channel.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Scheps\ Omni\ Channel.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Scheps\ Omni\ Channel.bundle/Contents/MacOS/AVXMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Scheps\ Omni\ Channel.bundle/Contents/MacOS/AVXMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/KingsMic.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/KingsMic.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/EddieKramer\ VC.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/EddieKramer\ VC.bundle/Contents/MacOS/GenericMacIntel.dylib
NOTES:
After running Plugins ‘Reset and Restart Validation’ in Logic Pro some Dylibs CANNOT BE SORTED OUT , so any plugins with following messages in Logic Pro’s ‘Report’ will show following type of errors (which seems to be a trend):-
1. Plugins that report an error of Input Format: AudioStreamBasicDescription: 1 ch, 44100 Hz, 'lpcm' etc… may crash validation - dylib cant be sorted.
2. Any plugins that show objc[24298]: Class wvWavesV12_7_0_181_WCCustomMenuView is implemented in both /Library/Audio/Plug-Ins/Components/WaveShell1-AU 12.7.component/Contents/MacOS/WaveShell1-AU (0x10843c088) and /Applications/Waves/Plug-Ins V12/WavesLib1.14_12.7.framework/Versions/A/WavesLib (0x109420f88). One of the two will be used. Which one is undefined. Can’t be sorted
3. Any plugins requiring dylibs that have AVX512.dylib will fail.
AudioGod
@Driftwood Thats awesome buddy, Make a new thread under Tutorials for the waves fixes.
That is super helpful stuff for a lot of people. 👍
Great work. I'm sure many people will find this super useful.
SimeJah
ok So i have been trying to get Puigtec working for days now. After running the commands above in the terminal I still get the same error when trying to rescan. What am I doing wrong?
Any help is greatly appreciated.
Big Sur 11.5.2
Logic Pro X 10.6.3
Waves 12 (puigtec 12.0.7 legit license)
tomnic
Big Sur 11.5.2
Logic Pro X 10.6.3
Try replacing the whole bundle with the attached PuigTec.bundle file, unzip and replace contents in:
...also replace libmkl_waves.dylib with this patched one https://drive.google.com/file/d/1LICjUgCyx-8Akx4Mf2vpBJLliEz2bRJl/view?usp=sharing in:
/Library/Application\ Support/Waves/Modules/MklWaves.framework/Versions/A/
Then manually validate this plugin, tell me if it works, it does for me using Puigtec 12.7.0.
  • PuigTec.bundle.zip
thirty3
Hey, I'm new here and made this account just to post some seemingly really good news.
I just wanted to post here and tell you all that while running Big Sur, Legitmate, Licensed Waves 13 plugins seem to work without modification using the command MKL_DEBUG_CPU_TYPE=5 /Applications/Logic\ Pro\ X.app/Contents/MacOS/Logic\ Pro\ X to launch the current version of Logic Pro X
(They do not work trying to launch it the normal way)
Plugins like H-verb, Grand Rhapsody, and LoFi Space seem to work fine. It does take a little longer for the "checking plugin" phase to pass though.
I'm running an AMD 5950X and I have a logic session open right now that works as I write this.
Screenshots for proof
RyzeCooker
santosh mareddy
I tried everything but nothing seems to work
AMDPUSH
i saw with AMDFriend some people have good results, i haven't try myself, but i'am looking at it
AMDPUSH
it s working for me, on 11.6.5
joeysaran
is Clariry VX work ?
