Get The Following Problematic Plugins From Waves Working On AMD.
NOTES:
After running Plugins ‘Reset and Restart Validation’ in Logic Pro some Dylibs CANNOT BE SORTED OUT , so any plugins with following messages in Logic Pro’s ‘Report’ will show following type of errors (which seems to be a trend):-
1. Plugins that report an error of Input Format: AudioStreamBasicDescription: 1 ch, 44100 Hz, 'lpcm' etc… may crash validation - dylib cant be sorted.
2. Any plugins that show objc[24298]: Class wvWavesV12_7_0_181_WCCustomMenuView is implemented in both /Library/Audio/Plug-Ins/Components/WaveShell1-AU 12.7.component/Contents/MacOS/WaveShell1-AU (0x10843c088) and /Applications/Waves/Plug-Ins V12/WavesLib1.14_12.7.framework/Versions/A/WavesLib (0x109420f88). One of the two will be used. Which one is undefined. Can’t be sorted
3. Any plugins requiring dylibs that have AVX512.dylib will fail.
Perl:
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/CLA\ EchoSphere.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/CLA\ EchoSphere.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/CLA\ MixDown.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/CLA\ MixDown.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Butch\ Vig\ Vocals.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Butch\ Vig\ Vocals.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/EddieKramer\ BA.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/EddieKramer\ BA.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/IR-L.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/IR-L.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-EQ.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-EQ.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-TripleD.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-TripleD.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-Distortion.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-Distortion.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-ToneShaper.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MannyM-ToneShaper.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/MetaFilter.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/PuigTec.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/PuigTec.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/PuigTec.bundle/Contents/MacOS/IR_Calc.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/PuigTec.bundle/Contents/MacOS/IR_Calc.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Scheps\ Omni\ Channel.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Scheps\ Omni\ Channel.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Scheps\ Omni\ Channel.bundle/Contents/MacOS/AVXMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/Scheps\ Omni\ Channel.bundle/Contents/MacOS/AVXMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/KingsMic.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/KingsMic.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' /Applications/Waves/Plug-Ins\ V12/EddieKramer\ VC.bundle/Contents/MacOS/GenericMacIntel.dylib
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' /Applications/Waves/Plug-Ins\ V12/EddieKramer\ VC.bundle/Contents/MacOS/GenericMacIntel.dylib
NOTES:
