Hello guys ,
i hope you're all fine
i'm trying to test ventura on my gaming pc , i succefully created an EFI that boots up , acces the disk utility and other tools , but when i click on install macOS ventura , it says that macos cannot be installed on this computer.
my config :
CPU : AMD ryzen 3600x
RAM : 32go
MB : gigabyte B450m DS3H
GPU : RTX 2070 ( ps : i know this gpu is not supported , i just want to install and try ventura to see if it suits my needs for a couple of time before buying an amd gpu)
i used Opencore to creat the EFI , and downloaded official ventura and installed it using the command line provided by apple.
i used OCAuxiliaryTools to configure my EFI, i applied amd patch, edited algrey, uuid key and tried different SMBIOS configurations , same result .
please find attached my EFI , thanks in advance guys !
my config :
RAM : 32go
