Upgrade Monterey to Ventuna 13.2.1, installer stuck in [EB|LOG:EXITBS:START]
kenny
Hello everyone
I've created a new APFS volume for Ventuna and run the installer from Monterey. When it restarted, it stuck.
Opencore is the latest 0.9.0. I've checked the kernel patches (the cpu core numbers) and all kexts are updated. Monterey 12.6 works on the same config.
I've attached the EFI and the opencore log.
The hardware list,
Gigabyte X570 I AORUS PRO WIFI
AMD 3700X
AMD RX5500XT
64 GB DDR4 RAM
Samsung 970 EVO Plus 1TB
  • opencore-2023-03-12-log.txt.zip
Are you using the latest AMD-OSX kernel patches?
mariettosun
no he doesn't..and also he is using 2 ethernet kext for the same i211 I think and one of them is not working for sure
leesurone
As Mariettosun pointed out you have 52 kernel patches being loaded where there should only be 19, 18 of which are used. See here:
kenny
Thanks for the replies. I've removed all the items under the kernel patch and copied in the latest one. With the correct core number set, the problem has been solved.
I attached the new config.plist in case someone has a similar issue.
AMD 3700X
kenny
Finally got Ventuna works on my mb. Here's a trick for those with similar hardware.
By the time of this post, the kext for the intel wifi shall be the 2.2.0 debug version for Ventuna, otherwise, it gets stuck in the login window.
And I disabled AppleIGB.kext as mariettosun pointed out, using SmallTreeIntel82576.kext. I don't use a wire connection so I am not sure if it works.
