- Joined
- Nov 22, 2022
- Messages
- 1
Hi Hackintosher, hope you're doing awesome.
I created a hackintosh machine with opencore boot loader and it has been successfully installed and working fine except for graphic acceleration.
I installed this OS while my dGPU was connected and now I want to remove my dGPU and want to use my Intel UHD 630 iGPU (Because my dGPU is AMD R7 240 which is natively not supported and I'm not getting any graphic acceleration as well.)
But when I use my iGPU via connecting a VGA port (because my HDMI port is damaged) in my MB, my monitor shows "No Signal From Your Device" after the verbose.
I'm pretty sure the macOS loaded successfully but somehow my iGPU/MB is unable to send a signal to the monitor. I've tried "Connector-type-patching" but nothing is working for me.
I need serious help to fix this, please help me out.
My Specs:
CPU: Intel i5 8400 (Coffee Lake)
iGPU: Intel UHD 630
MB: ASUS PRIME B360M-D2
Using:
Platform Id: 07009B3E (also tried 00009B3E)
iGPU Device Id: 3E928086
My Specs:
iGPU: Intel UHD 630
Using:
