Tahoe Installation on B850
Koffein71
13
Ryzen 9800X3D
Hi Forum,
my old Haswell Hackintosh got broke before christmas and now i've got a new PC with this items:
CPU: Ryzen 9800X3D
MB: MSI MAG B850 TOMAHAWK MAX WIFI
RAM: Kingston FURY DIMM 64 GB DDR5-6000 (2x 32 GB)
SSD: 2x WD Black SN8100 4TB (PCI-E 5.0) (1xWin11 1xLinux)
1x WD Black SN850 2TB (PCI-E 4.0) free for macOS
1x Crucial MX500 2TB (SATA3) with a macOS Tahoe installed on my old broke Hackintosh
GPU: Radeon 6800
Internal LAN will not be used, because it would not supported by macOS. Instead i will use USB2LAN adapter.
My goal is to boot the Tahoe installation on the SATA SSD and then to clone it to the 2TB nvme.
I've tried to create an EFI with OpCore Simplify but the attempt failed as espected.
Further trials with Dortania Guide and a lot of forum readings failed too.
I use OpenCore 1.0.6-DEBUG and most kexts are debug version too.
AMD patches (beta) has been applied and ACPI files has been mostly generated by SSDTTime.
Most attemps end with this log line:
AAPL: #[EB|LOG:EXITBS:START]
I am not sure about the root cause, found nothing about B850 builds, so maybe there is a specific problem with this chipset.
Has someone of you experience with AM5 B850 boards ? Are there any obstacles i am not aware of ?
As attachment my EFI folder and the logfile of last boot attempt.
Perhaps someone can provide some clues?
this config has WEG disabled and scanpolicy set for your disk configuration (i am using my default EFI and i forgot to put scanpolicy for your system
Also you can try to disable -v in bootarg option
And maybe, we miss also a proper USB map you should try to do in windows with corpnewt tool
Next run with your config run into a kernel panic. One step further.
Last time i forgot to reinsert my serials into PlatformInfo item.
The USB port map with the Windows tool gave me a UTBMap.kext,
but i didn't used atm. Is this realy needed to boot from the SATA SSD ?
I think the keyboard should work on the USB2 on board panel ?!
Edit: your config shows all the bootable drives now.
Don't ask me. I tried an install with Fabiosuns EFI and an USB Tahoe install stick I have made with a VMware virtual machine.
And believe it or not, I write this line on a fresh italian macOS Tahoe. And Italian keyboard layout. Great.
Now I switch to German if possible. Will give more info after reboot.
A BIG THANK YOU to Fabiosun :-)
  • Haha
Reactions: fabiosun
