Solved Tahoe Beta #3
113
Beta #3 installed successfully on these systems so far:
  • Intel:
    • Asus ROG Strix Z690-I mini-ITX via Software Update
    • Gigabyte Z390 Designare via USB install disk (because I wanted to test the Beta 3 install disk)
    • Asus Z690 ProArt via Software Update
  • AMD
    • Gigabyte B550 Vision D (AM4) via Software Update
Install failures:
  • AMD
    • Asus X670E Gene (AM5) because:
      • USB install disk freezes at 17 Minutes Remaining
      • Software Update does not work likely due to an issue with RestrictEvents
WARNING:
  • FileVault gets enabled by default
  • Be sure to open System Settings -> Privacy and Security -> FileVault and turn it off (must wait until encryption is done, then turn it off and wait for decryption)
  • Failure to do this means you may not be able use your login password on the next reboot
New default background is a photo of Lake Tahoe. Prior to login, the water will move...
@CaliMark
Beta 3 is occasionally causing an instantaneous reboot on my Asus X670E Gene. I’ll send a few crash reports to Apple, but Beta 1 was stable on this system.
I’ll also disable some kexts to see if one of them might be causing a problem.
@CaliMark
SOLVED: Simply updating OpenCore and Kexts to release versions has fixed all of these problems with my Asus X670E Gene.
