- Joined
- Jun 7, 2020
- Messages
- 3
Specs
What's Working?
Important
If you don't need to disable the second video card, just remove If SSDT-GPU-DISABLE from the config and from the ACPI folder. If necessary, you should use own ACPI paths and recompile SSDT-GPU-DISABLE:
USB-Map.kext is unique, even if you have the same motherboard model. Use your own ACPI paths values: https://dortania.github.io/OpenCore-Post-Install/usb/manual/manual.html
github.com
- CPU : AMD Ryzen 5 3600 6-Core Processor
- Motherboard : MSI Tomahawk B450 Max
- Memory : Patriot Viper Steel DDR4 32Gb (4x8GB)
- Video Card : GFX0 GK208B GeForce GT 710
- Video Card : GFX1 GA104 GeForce RTX 3070 - disabled via SSDT-GPU-DISABLE
- Keyboard : A4Tech KV-300H
- Mouse : Logitech G305
What's Working?
- [x] BigSur 11.6.7
- [x] Restart and Shutdown.
- [x] Bluetooth and ethernet
- [x] Audio - Rear Jack (Green) + Front Speaker Jack (Headphone)
- [x] iCloud, iMessage, Face Time
- [X] Sleep
- [x] etc
Important
GitHub - denmorgenshtern/Hackintosh-AMD-Ryzen-5-3600-MSI-TOMAHAWK-B450-MAX
Contribute to denmorgenshtern/Hackintosh-AMD-Ryzen-5-3600-MSI-TOMAHAWK-B450-MAX development by creating an account on GitHub.
