Stuck on "Using default recoveryOS logarchive preservation timeout"
nocaptony
Specs: Ryzen 3 1200
Asus Prime B450M-A
PowerColor RX 590 8gb
OLOy WarHawk RGB 16GB @3200mhz
I've been trying to install Big Sur to no avail. The installer seems to be getting stuck on "Using default recoveryOS logarchive preservation timeout", and there doesn't seem to be many online solutions. I'll attach my EFI and the opencore log below. Any help is appreciated.
  • opencore-2021-12-07-062223.txt
Config seems ok, I'd change npci=0x3000 for 0x2000 if you don't have above 4G in the BIOS. From a quick search it seemed to be an issue in early builds of Big Sur and has since been fixed. Ensure you've downloaded the latest version and remake the Installer but use your same EFI.
nocaptony
Yup, the installer was the problem. Downloaded the latest version from the app store, changed npci=0x2000, and installed Big Sur with no problems. Thanks for the help.
ian5267
Could someone please help I'm getting this same error
