Stuck on OCB:LoadImage Fail : Unsupported
Paradise
Hi all, this is my first trial with hackintosh and OC but i have some difficulties
my configuration
MB: B550 Aorus Elite V2
CPU: Ryzen 3700x
GPU: RX550 Sapphire Pulse
i used OpenCore 0.7.0 and I followed the guide
somebody did have the same issue?
Check you've got the required UEFI Drivers in OpenCore, if you do enable JumpstartHotPlug in UEFI -> APFS in your config.
Paradise
what you mean with UEFI drivers? i have installed these ones
  • HfsPlus.efi
  • OpenRuntime.efi
but with JumpstartHotPlug disabled​
You should have at least OpenHfsPlus.efi and OpenRuntime.efi in your EFI Drivers folder. Check that setting I mentioned in the config though.
Paradise
Thanks, I will try this evening
I already have another NVME SSD with WIN10 already install (not the same NVME where I will install Catalina) , could this cause problems?
Should I remove it for the installation)
Shouldn't cause any issues being a different drive. You should be fine. Remove it if you've any worries.
