stuck on hid: legacy shim 2
sasta
ryzen 7900x
I am trying to install Ventura, but I am stuck on hid: legacy shim 2.
Read some tips online, but I can't get unstuck
Asus x670e tuf gaming plus wifi
Ryzen 9 7900x
I am attaching efi folder and acpi files
Thanks in advance
Which discrete AMD GPU are you using?
Amd 6800
I changed my usb map but now I am stuck at couldn't alloc class "AppleKeyStoreTest
Try using your installer in a USB2.0 port. Sometimes USB3 ports don't work when installing macOS, due to incorrect settings in USB configuration.
You don't need SSDT-PMC.aml with your AMD system, it is meant for use with an Intel Z390 or similar motherboard. Remove the SSDT and config.plist entry.
You an also try this cleaned up version of your EFI, to see if this helps.
