Stuck between "RTC: Only Single RAM" and "[PCI configuration begin]"
Huaba1998
Hello Guys,
i need help.
I'm stuck somewhere between RTC: Only Single RAM bank and [PCI configuration begin]
its always freezing somewhere between these lines.
OS: 10.15 Recovery (build from a Windows machine)
CPU: AMD Ryzen 5800X
Motherboard: ROG Crosshair VIII Hero (WI-FI)
GPU: Sapphire Pulse RX 580
i don't know if thats the Problem but have CSM Enabled because my Motherboard says it needs to be enabled because my GPU isn't supported.
here is my EFI:
https://drive.google.com/drive/folders/1rfw9WbMpLPOldU38NtCSdHM5JH1gISMk?usp=sharing
If you need more information just tell me
Thank you
Moozuki
I've never had to enable CSM for either of the RX 580's I have on any MB that I've used. You might want to look into that some more, doesn't sound right to me.
m0>
That Sapphire card should be an OOB gpu. I had issues with a reference 580, but pretty much anything 580 by Sapphire should have no issues with GOP, etc.
