stuck at bootkernelextensions or something
gabsuki
AMD A6-7480
this is the error im getting when booting the mac os recovery image, is there any way out of this? i tried searching the guide and the internet for a fix but i cant seem to find one. im using the latest version of opencore release (also getting this error with debug ver)
Tell us about your system and we may be able to help.
As it stands we don't know which CPU, Motherboard or graphics card you are using. So you are unlikely to receive any help without some more input from yourself.
CPU DualCore AMD A6-7480, 3800 MHz
GPU AMD Radeon R5 Graphics (8 GB)
Motherboard make and model?
Clarify which graphics card you are using.
I've not heard of an R5 dGPU having 8GB VRAM. If this is an integrated GPU, part of the CPU, then it won't work. As macOS doesn't support any AMD Integrated GPU's.
You need a macOS compatible AMD or Nvidia discrete GPU to run macOS on an AMD system. See this GPU Buyers guide :
AMD - https://dortania.github.io/GPU-Buyers-Guide/modern-gpus/amd-gpu.html
Nvidia - https://dortania.github.io/GPU-Buyers-Guide/modern-gpus/nvidia-gpu.html
