Sonoma 14.4 Success
keef247
OpenCore 0.9.8/Sonoma 14.4 working perfectly. Just updated any kexts to the newest.
MSI B450i Gaming AC PLUS MITX
Ryzen 3600
Gigabyte RX 570 Gaming 8G
2x8GB 2666MHz random ram
Crucial MX500 2TB SATA3 SSD
Pretty happy with this considering it's only 2 days old release wise :)
Onboard BT/Wifi works too :)
Anyone wanting to do this, just make sure that you're on the latest version of OpenCore with all your kexts updated, then do the usual create a usb bootable drive then add your EFI, install/upgrade via booting from the USB, copy the EFI over afterwards, done. This has worked for me on every update of Sonoma.
I have had issues trying to do it from simply launching the installer within macos, IIRC it worked with 14.0 or 14.1 but then not after that, either way this is cleaner, and seems to just work.
baronerosso
do you have intel wifi? which extension do you use? I have the Intel AX200 and it only works with open networks, I can't authenticate.
keef247
