Sometime boots sometimes don't... need help
michigo
Good day everyone,
I need some help with my EFI configuration.
My system:
MSI B350 Tomahawk
Ryzen 7 2700x
Corsair 32GB 3000
MSI 470 8GB
Not anytime the system like to boot. I need to use my installer USB driver to boot to the system, when I need to reboot to boot normally from ssd... I don't have any idea why it's happen.
Need some help please!
Some boot logs:
00:000 00:000 OC: Kernel patcher result 7 for kernel (algrey - cpuid_set_cache_info - cpuid 0x8000001D instead 0 - 10.13/10.14) - Not Found
00:319 00:319 OC: Kernel patcher result 28 for kernel (algrey - tsc_init - remove Penryn check to execute default case 10.14) - Not Found
Good day everyone,
My system:
MSI B350 Tomahawk
Ryzen 7 2700x
Corsair 32GB 3000
MSI 470 8GB
Some boot logs:
Hi Michigo,
Okay, so I've had a look at your EFI. Seems you have a string of issues including not enabling a number of SSDTs required for your board such as SSDT-CPUR.aml.
Anyways I've made some adjustments and added some files from my working Catalina B550 Ryzen 5900X build including updating your SMBIOS details. Give it a try.
  • michigo EFI Catalina.zip
michigo
Hi Michigo,
no luck(
it's don't even try to boot from usb drive
no luck(
What format did you set your USB drive to? It should be able to read - try using macOS Extended with GUID Partition Map.
