[SOLVED] Opencore no longer showing at startup- Requires USB
Hbg1968
hi, I recently tried to update to the latest version, but stuffed up completely. I was running 0.5.7? I just did a setup and was able to boot up using 0.6.2, however Opencore no longer shows up unless I use the USB key to startup. Without the USB key, it only shows the SSD's as well as Windows Boot Manager.
I did try using 0.7.7, but had issues.
Attached is my Config.plist. I used the EFI from TechTunerLife on Youtube, and other than this seems fine.
Hbg1968
