[SOLVED] Cinema 4D R22 and R23 Fail to load
winterwolf
Wondering if anyone else is experiencing this problem where R22 will begin loading, but stick on "initalizing layout" forever. And R23 just crashes outright. Guessing there may be an Intel library it's looking for or something? Here's a shortened crash report.
UPDATE: I replaced the /Applications/Maxon Cinema 4D R23/corelibs/../resource/modules/denoiser.module/libs/osx/libOpenImageDenoise.dylib
with the R21 version of the Denoise Library and now it boots to "Initalizing Layout" but then locks up.
UPDATE 2: So it looks like the best thing to do is delete the entire application and preferences (~/Library/Preferences/Maxon/Maxon Cinema 4D R23_#######)
Reinstall and then before opening it, delete all the denoiser files.
corelibs/denoiser.module.xlib
It's an intel denoiser, so copying the previous versions in there probably wouldn't work anyway.
Boom! Now it works.
Process:               Cinema 4D [2240]
Path:                  /Applications/Maxon Cinema 4D R23/Cinema 4D.app/Contents/MacOS/Cinema 4D
Identifier:            net.maxon.cinema4d
Version:               23.0 (323902)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Cinema 4D [2240]
User ID:               501
Date/Time:             2020-10-22 15:50:06.982 -0400
OS Version:            Mac OS X 10.15.6 (19G2021)
Report Version:        12
Anonymous UUID:        #########
Time Awake Since Boot: 1900 seconds
System Integrity Protection: disabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_PROTECTION_FAILURE at 0x00007ffedfa77ff8
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [2240]
VM Regions Near 0x7ffedfa77ff8:
    MALLOC_MEDIUM (reserve 00007fcd28800000-00007fcd30000000 [120.0M] rw-/rwx SM=NUL  reserved VM address space (unallocated)
--> STACK GUARD            00007ffedc278000-00007ffedfa78000 [ 56.0M] ---/rwx SM=NUL  stack guard for thread 0
    Stack                  00007ffedfa78000-00007ffee0278000 [ 8192K] rw-/rwx SM=ALI  thread 0
Application Specific Information:
tomnic
Sorry but it doesn't work for me for R23... it still remains in the layout loading page... any other clue?
Just gets stuck here then crashes after removing those files.
Must've been a bad install. Working just fine now,
eye
Hi there ,, I had some issue But it solved ,, Just uninstall r23 and install again, don't delete anything and not use crack file. After installation finished just start C4D. Licensing screen will appear, Walt here just few second to be sure it fully loaded, than just close it , do this step maybe for two times more and than crack the software and open it, it should be working...
Olusola David Ayibiowu
Hi, it works.
