- Joined
- May 27, 2020
- Messages
- 72
MacOS Catalina thinks my internal M.2 NVMe SSD is an external drive. I found a solution that worked for me at this link on Reddit.
Essentially, you use Hackintool to find the device path of the storage device. In my case, the device path is: PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)
From there, you edit your config.plist to add an entry under DeviceProperties and also set Kernel/Quirks/ExternalDiskIcons to true.
The step by step instructions are on the Reddit link above.
![External drive fix.png External drive fix.png](https://forum.amd-osx.com/data/attachments/0/503-3487a0b7e7b5af649d3982cc4f335226.jpg)
